mlapaglia Getting comfortable Apr 6, 2016 849 508 Jun 22, 2017 #1 Does anyone know where I can purchase a replacement turret lens glass cover? I broke the glass and need a new one.
fenderman Staff member Mar 9, 2014 36,891 21,411 Jun 22, 2017 #2 mlapaglia said: Does anyone know where I can purchase a replacement turret lens glass cover? I broke the glass and need a new one. Click to expand... buy a bricked camera on ebay...
mlapaglia Getting comfortable Apr 6, 2016 849 508 Jun 22, 2017 #3 The glass seems to be glued in place, I don't know if I'd be able to get it out of a donor camera without breaking it.
fenderman Staff member Mar 9, 2014 36,891 21,411 Jun 22, 2017 #4 mlapaglia said: The glass seems to be glued in place, I don't know if I'd be able to get it out of a donor camera without breaking it. Click to expand... heat it...i doubt you will find parts available...did you drop it?
