Turret cam vertical mounted...
Lincos
Nov 4, 2019
20
10
Netherlands
Hi all,
I still not have a nice set up over here and i have to start all over again.
I have a question. Can i mount the Turret cams directly to a vertical wall? Such as the PC-T5442T-ZE, or the IPC-T5442TM-AS ?
Cheers!
Take a look at the Dahua spec sheet once you identify the camera you will be using. The spec sheet will show the compatible mounts.
The 5442 on a PFB204 looks very professional and is easy to mount. You simply mount an included plate, and then the rest of the mount slips over the plate and screws down tight. Make sure you read the wiki on waterproofing for this type of a setup.
Reactions: Lincos
