GL.iNet Devices Model GL-AR300M16-Ext
GL-AR300M Series / Shadow - GL.iNet (gl-inet.com)
A big whopping $30!!!
They can be configured in may different ways. As a mini travel router, WiFi repeater, Access Point, etc.
Configure them in Repeater Mode, connect to your SSID, plug your camera into the LAN port and voila. You have an ethernet port connected to your WiFi. Hands out an IP address just as if you are on WiFi (not it's own unique network). DHCP works, Static IPs work! And they run on a custom OpenWRT distro.
Have fun!
Have fun!
Been rocking a few of them for weather, access point, and network diagnostics while in the field.
