- Dec 8, 2017
- 3
- 0
TScam SP-P1803SZ-POE  purchased from DHGATE.. came with a pan and tilt bracket  protocol Pelco-d/P input 12vdc address code 1
The camera has a rj-45 connector, a presumably gray power connector, a unknown red connector, and a green rectangle connector with two male pins in a female socket.
The Pan and tilt has a well marked DC power in, an apparent power out that plugs in to the camera gray connector, and two loose wires with male pins....
The camera works the PTZ is set to Pelco-D , no options to set a network code, zoom works. the pan and tilt are hard locked on a "home" position after init left-right up-down....
Same issue with Blue Iris and direct IP access.. i am unable to access any of my hardware settings pages on Blue Iris but as this is also an issue with I.E and direct ip access I am thinking its a wiring issue.. Thoughts ????
