Can anyone upload a picture or drawing of how you are suppose to wire these Bosch OD850 Tri-Tech outdoor PIR's? I successfully wired 3 indoor Bosch Gen2 PIR's (with the blue LED) fine and dandy. Thought I could just simply copy what I did for the indoor models to the outdoors. Nope, always showed 'open' on the keypad.
The method in the picture below finally satisfied the keypad but nothing triggers it during testing. The unit does get power (green & red LED lights go off upon approach). If I move the EOL resister to the other NC/T, keypad says it's open.
Thought maybe bad port on the DSC 1834 so moved it over to another port....same issue.
I did search through these forums....and via google. Amazing that there is little out there for this model.
