Trying to telnet in Romeifly camera
elk1007
May 5, 2022
1
USA
Hello, I am attempting to use an app-only IP camera over telnet.
This is the product on amazon.
The product is called Romeifly camera is intended to be used with a Google Play app called HWDV Cam.
The cam needs to be set up to the wifi, and then can be accessed via app.
If I use Zenmap, I see that the camera has port 23 open (telnet).
Using Putty, I can connect to the camera's static internal IP, and its asks for a login.
Any idea what this might be?
I have tried root and blank pass.
I also tried root and xmhdipc.
EDIT: The main chip on this cam says
Hi3518
ERNCV300
