I have been sending XML files to hik vision UK and they have been Sending back XML file so I can reset my password. However, I got this email back after submitting the XML file from one of my cameras. The cameras definitely manufactured by HikVision, so I'm not sure what they are going on about.
Dear Customer,
Thank you for your email to Hikvision UK & Ireland. As an End User of Hikvision products we would recommend you contact you point of purchase/installer for all technical support. If you do not have an installer we would recommend you to contact one in your local area.
We only support end users with Hi Look or Hi Watch products, if you got Hikvision products please contact your installer/supplier for any help.
Dear Customer,
