trying to get the PTZ going on a zosi C289 with ispy
Cartel
Aug 8, 2021
14
2
Canada
I can get the video with no password with rtsp:/192.168.1.55:554/video1 and */video2
but thats it, the ptz wont work. I'm using a router and a laptop with ispy. it was working with a previous ptz camera but it died.
Heres some screenshots of the onvif tool and some dead ends.
onvif gives a link
Code:
http://192.168.1.55:8080/onvif/device_service
for onvif device but its a 404 with links to "happytime" site?
I also used a zosi search tool to get more infor.
onvif tool says ansjer IPC
thanks
ScreenShot008.jpgScreenShot007.jpgScreenShot005.jpgScreenShot004.jpgScreenShot003.jpgScreenShot002.jpgScreenShot001.jpg
I think I got in on telnet....what do I do?
Code:
(none) login: root
Password:
Login incorrect
(none) login: root
Password:
Welcome to Linux.
None of nfsroot found in cmdline.
~ # ps
PID   USER     TIME   COMMAND
    1 root       0:08 init
    2 root       0:00 [kthreadd]
    3 root       2:08 [ksoftirqd/0]
    4 root       0:00 [kworker/0:0]
    5 root       0:00 [kworker/0:0H]
    6 root       0:00 [kworker/u2:0]
    7 root       0:00 [lru-add-drain]
    8 root       0:00 [kdevtmpfs]
    9 root       0:00 [netns]
  174 root       0:00 [oom_reaper]
  175 root       0:00 [writeback]
  177 root       0:00 [kcompactd0]
  178 root       0:00 [crypto]
  179 root       0:00 [bioset]
  181 root       0:00 [kblockd]
  184 root       0:00 [spi0]
  187 root       0:00 [spi1]
  211 root       0:00 [cfg80211]
  292 root       0:00 [rpciod]
  293 root       0:00 [xprtiod]
  300 root       0:00 [kswapd0]
  351 root       0:00 [nfsiod]
  393 root       0:00 [bioset]
  394 root       0:00 [bioset]
  395 root       0:00 [bioset]
  396 root       0:00 [bioset]
  397 root       0:00 [bioset]
  398 root       0:00 [bioset]
  399 root       0:00 [bioset]
  400 root       0:00 [bioset]
  401 root       0:00 [bioset]
  402 root       0:00 [bioset]
  403 root       0:00 [bioset]
  404 root       0:00 [bioset]
  405 root       0:00 [bioset]
  406 root       0:00 [bioset]
  407 root       0:00 [bioset]
  408 root       0:00 [bioset]
  448 root       0:00 [bioset]
  453 root       0:00 [bioset]
  458 root       0:00 [bioset]
  463 root       0:00 [bioset]
  473 root       0:00 [kworker/u2:2]
  506 root       0:00 [irq/26-mmc0]
  508 root       0:00 [irq/27-mmc1]
  509 root       0:05 [kworker/0:2]
  524 root       0:01 [jffs2_gcd_mtd3]
  771 root       0:00 init
  773 root       0:00 telnetd
  822 root       7:20 [irq/41-VI_CAP0]
  872 root       0:00 [dog]
  934 root       0:28 ./applauncher
  937 root     172:00 ./NewIPCam.exe
 1042 root       0:30 [RTW_CMD_THREAD]
 1074 root       0:00 hostapd -B -d /etc/hostapd.conf
 1080 root       0:00 udhcpd /etc/udhcpd.conf
 1213 root       0:02 {monitor_venc.sh} /bin/sh /app/monitor_venc.sh
14263 root       0:00 -sh
15343 root       0:00 sleep 45
15485 root       0:00 ps
Code:
~ # netstat -utlp
netstat: showing only processes with your user ID
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
PID/Program name
tcp        0      0 0.0.0.0:554             0.0.0.0:*               LISTEN
937/NewIPCam.exe
tcp        0      0 192.168.1.55:webcache   0.0.0.0:*               LISTEN
937/NewIPCam.exe
tcp        0      0 0.0.0.0:telnet          0.0.0.0:*               LISTEN
773/telnetd
netstat: /proc/net/tcp6: No such file or directory
udp        0      0 0.0.0.0:18152           0.0.0.0:*
937/NewIPCam.exe
udp        0      0 0.0.0.0:18154           0.0.0.0:*
937/NewIPCam.exe
udp        0      0 0.0.0.0:32761           0.0.0.0:*
937/NewIPCam.exe
udp        0      0 0.0.0.0:32520           0.0.0.0:*
937/NewIPCam.exe
udp        0      0 0.0.0.0:32530           0.0.0.0:*
937/NewIPCam.exe
udp        0      0 0.0.0.0:32540           0.0.0.0:*
937/NewIPCam.exe
udp        0      0 0.0.0.0:bootps          0.0.0.0:*
1080/udhcpd
udp        0      0 0.0.0.0:53091           0.0.0.0:*
937/NewIPCam.exe
udp        0      0 0.0.0.0:3702            0.0.0.0:*
937/NewIPCam.exe
netstat: /proc/net/udp6: No such file or directory
