Trying to figure out this memory leak
crespoh69
Mar 12, 2023
10
CA
OS: Win 10
Memory: 8GB-16GB
Cameras: 6
BI Version: 5.9.1.6
I'm currently running version 5.9.1.6 on a bare metal VM that seemed to have been working for a couple of months then all of a sudden it's started to crap out. I've gone ahead and isolated to what appears to be the camera I added back in November, an Annke FCD600. I'm currently running 6 cameras, all of the other ones are Annke C500's and 1 Reolink Duo 3. I've tested the VM with memory ranging from 8GB to 16GB but after a couple of days it starts to eat more and more memory until Windows hangs.
Has anyone used the FCD600 and experienced similar issues? Any workaround you found? I normally copy another cam when adding new ones but I've also tried to just add this one from scratch with the same results. I'm unsure if there's a particular setting on the cam end that's killing things but am also unaware of how I'd go about troubleshooting further. I did also go and physically test the line using a microscanner2 with no issues shown on the lines going up to the switch or the camera so I'm a bit at a loss right now.
