I have an Amcrest Qcam 3-Megapixel 8Ch Network POE Video Security System which came with four bullet cameras. I would like to add two dome cameras to this setup, but Foscam/Amcrest doesn't make any.
I purchased two GW-1371IP cameras from Amazon that support POE and, supposedly, ONVIF. I can get them to connect to my NVR through my home network on a 192.168.x.x address, but not directly to my NVR. I logged directly in to the cameras and enabled DHCP, but the NVR will still not pick them up. The NVR uses 172.16.xx addresses for the existing bullet cameras. I downloaded ONVIF Device Manager and connected directly to the G-1371IP cameras while they are attached to my home network. If I enable DHCP on the cameras, it forces the DNS to 202.96.134.133 and that value can't be changed, nor can it be dynamic.
If I disable DHCP, I can set IP, Subnet Mask, Default Gateway, and DNS to whatever values I like, except that the IP and the Default gateway have to be in the same range (i.e., I can't have a 172.16.x.x IP and a 192.168.x.x default gateway). Any suggestions on proper configuration? Or are these cameras just not going to work with the NVR?
