I have seen youtubers, read alot here including Reolink threads.. which put me away from reolink, unless just for added cheap day camera.
I guess Dahua and Hikvision is promoted here for good video quality at night and compatability with BlueIris.
some questions:
1) if I choose to skip BlueIris and go for a NVR, lesser options, but maybe less fixing computer,
which NVR would work better if I mix Hikvision and Dahua cameras?
2) deciding which Camera and focal-lenght:
I am looking at Dahua 5442 and Hikvision xxx , not sure if I really need variofocal - if color low light is worth the money.
In front of house I can only view 4.5 meters since Law in Sweden forbids taking Photo/video outside my yard using fixed cameras.
Yard is 30x30 meters and I will probably have 2 cameras in each end of 18 m long house, house is 10m wide .
In the back of house I have approx 12 m until end of yard.
If I understand right - this means 2.8 mm is probably ok for me, since max distances from camera to anything are 4.5 m to 12 m?
Will vari-focal be useless/waste of money for me with these short distances?
3) Dahua
It is a little bit hard to see if I should choose Dahua 5442 or one level below in quality for price - which number would that be?
looking at these two
IPC-T5442T-ZE 4MP Starlight IR Vari-focal Eyeball Network Camera
IPC-T5442TM-AS 4MP Starlight+ WDR IR Eyeball AI Network
- and thinking which serie (instead of 5442) to choose if going down one step in quality for lower price
What would I mainly loose with a cheaper version of Dahua compared to 5442 series?
4) Hikvision
I looked at maybe one more expensive version such as
DS-2CD2087G2-LU 4K Super ColorVu Fixed Bullet Network Camera
also looked at cheaper version - in order to maybe have both in different locations
Hikvision DS-2CD2046G2-I (2.8 mm) IP Bullet Surveillance Camera with False Alarm Filter Acusense
would I loose a lot of night vision with the 2046 version?
is there a better pick in Hikvision?
5) wifi versions
I am thinking of POE cameras - but also some Wifi outdoor due to more difficult to wire Ethernet.
Also some maybe wifi inside house.
Which Wifi versions would work similar to the other cameras mention above?
6) wifi inside
I tested these D-link DCS-8526LH which were ok for me inside decent night view even when moving inside, and pan & tilt and 2way audio., but not working with BlueIris made me skip D-link even though, they were ok.
If I want a similiar WIFI camera inside what should I choose?
7) 2 way audio and Dahua Hikvision - do they exist and are they ok?
or are they much more expensive / not as good video quality?
8) Dahua or hikvision - which are better in price performance?
some questions:
3) Dahua
4) Hikvision
5) wifi versions
6) wifi inside
