Hi. I am currently using Xprotect and am wanting to do a trial of Blue Iris. I have installed Blue Iris 5 on a separate machine to Xprotect. The separate machine is connected via ethernet to my router which is in turn connected to the POE switch that has my 3 cameras connected. The machine running Xprotect is connected directly to one of the ports of the switch. The cameras are set to RTP/UDP because I have had long standing issues when using TCP/IP which I was never able to resolve. TCP/IP causing the frame rate to fluctuate wildly in Xprotect and also I was getting some ghosting and artifacts. Despite Cat 5 E cable throughout and gigabit ports throughout. There seemed to be a bottleneck in my network which I could never identify. Anyway UDP has worked flawlessly with no lost packets. I'm only running 10 - 15 FPS by the way on three 2MP cameras.
I have tried adding a camera to Blue Iris without success. My cameras are Onvif and can be discovered no problem. I cam also see the cameras by browsing to the IP address no problem. I have also tried several different configs with no success. Does anyone have any suggestions on where to start?
Also - is it necessary for me to shut down the various services related to Xprotect while experimenting with Blue Iris, or can I have the streams simultaneously going to two different types of software on separate machines? I did shutdown all Xprotect services when I tried to add camera to Blue Iris but it would be easier not to have to do in future if not necessary.
