Log into each cam's webGUI (one at a time) abd assign a unique, static IP to each cam in the same subnet as the NVR's LAN and outside of the router's (if any) DHCP pool.Hi
Have a 16channel truvision nvr and 16ch poe switch.all ip cameras go to switch then one at 5 lead goes to port 1 of nvr.
No cameras display when discover cameras nothing found ????
Does your NVR also supply poe in addition to your switch? What it the model?Hi
So I have all cameras plugged into poe switch then about 1meter away the nvr one lead from poe switch plug into poe port nvr? Or should it go lan portI haven’t heard truvision in a long time! You have all cameras to a switch, to a camera port on nvr?
It should go to router.So I have all cameras plugged into poe switch then about 1meter away the nvr one lead from poe switch plug into poe port nvr? Or should it go lan port
That NVR provide its own subnet. What is the Model?So I have all cameras plugged into poe switch then about 1meter away the nvr one lead from poe switch plug into poe port nvr? Or should it go lan port
Truvision nvrThat NVR provide its own subnet. What is the Model?
Model NVR 11 truvisionThat NVR provide its own subnet. What is the Model?
POE CAM => POE SWITCH => ROUTERSo I have all cameras plugged into poe switch then about 1meter away the nvr one lead from poe switch plug into poe port nvr? Or should it go lan port
Is that a NVR1116S? if so, the NVR will assign a subnet that is different than that of the NVR . This video will explain what I am talking about? Interlogix TruVision IP & HD-TVI Programming Training (youtube.com)Truvision nvr
Go to count 1:21:08 on that video.Is that a NVR1116S? if so, the NVR will assign a subnet that is different than that of the NVR . This video will explain what I am talking about? Interlogix TruVision IP & HD-TVI Programming Training (youtube.com)
