I use Blue Iris 5.3.1.6 w32 (10.8.2020) on a 32bit Windows 10.
I integrated now my first ONVIF 1080p cam with a H.265 stream. (H.264 is not available)
Everything works fine with the exception of the direct to disk recording. (Working are viewing, streaming, Motion Detection, sound from microphone, Snapshots or recording with re-encoding)
But when a recording should be performed (manually or triggered) I find then this message in the log: "Clip: H265 encoder missing"
Why does it not save the stream "as is" ? On my test (eval license) Install I tested the same cam (on the latest 64 bit version) without any problems.
Where lies now the issue ? Something not installed ? Version of BI ? 32 bit Windows ? Cam stream faulty ?
