- Sep 29, 2016
- 23
- 4
My parents have a Lorex kit from Costco w/ four 4K bullet cams and an 8-port NVR, model NR908X-N. Installed everything a few weeks ago and it worked, 4 cameras showed up (ports 1-4) in web app, client, phone app, everything working properly.
Turns out the fan was too loud for them so they replaced it with a quieter one and put everything back together. Apparently the first time connecting after doing so only one of the cameras showed up, so they restarted it and since then none of them appear. They show up on the side of the web app, for example if all are disconnected and one is plugged into port 5, it shows CAM 5 (figure 1). However, the actual video never shows up. I see it in Setup/Camera Setting/Remote Device but haven't figured out how to do anything there. I even tried the "Reconnect IPC" button but it doesn't seem to do anything.
Anyone else experienced this before or know what the problem is? I don't think any changes were made besides power off, replace fan, and power back on, but the PSU may have been disconnected at some point from the rest of the components in the NVR in case that affects something.
