- May 18, 2017
- 58
- 12
Need some help installing UI3 on one of my desktop PCs running Windows 7 Pro. This is a separate computer in my office NOT containing my dedicated BI system.
I use ZeroTier, which is probably irrelevant at this point, but I've tried entering the LAN IP in my BI phone app (IP created by ZT) which works when I use UI3 on my Android phone, but fails to work on this PC since I don't think UI3 has successfully installed yet.
Steps I've taken:
From GitHub I downloaded the UI3 zip file, created a new folder c:\program files\blue iris 5\www, and tried to extract UI3-268 into it. It wanted to create a subfolder within www and I agreed. Nothing shows up in the www folder, no subfolder or files.
Next, I moved the UI3-268 zip into the www folder, then tried to unzip. Still nothing shows up.
It seems the unzip process isn't working, I must be doing something wrong and missing something basic about extracting. I was looking for an executable .exe within the zip container but don't see one.
Is UI3 compatible with Win 7 Pro?
Any advice?
Thank you.
Steps I've taken:
Any advice?
Thank you.
