Hello, Everyone. I'm trying to install a Hikvision DS-2CD2347G1-LU (4MM) 4MP ColorVu fixed turret camera on my 6 year old Hikvision DS-7604ni-se/p 4ch NVR (v 2.3.10 I believe). I had another camera in the first POE port (D1), and it died. From what I've read, I can't delete that camera's information from camera setup... I can only change it to match my new camera. I've been playing with the IP addresses on the NVR and camera, reading forums (mainly this one), and trying to use SADP. I think I'm just getting more confused. I just need to know what to change the camera's IP address to and what to change the NVR's IP address to, and please look at any other blanks in the pictures to see if they're correct. After playing with this daily for almost a week, I'm almost ready to buy a cheap Costco plug-and-play system where you just scan barcodes.
I really want to get this ColorVu camera working because I assist the local PD with footage a few times per year, due to my house being on a major street.
When I click the triangle button to see what the issue is, it always says "Disconnected" and that's it. Sometimes, the serial number will become visible as I play with the IP address, but the camera view never shows up. Hikvision support doesn't believe me that the triangle only says "Disconnected", and they want me to give them the rest of the error message. I haven't been connecting my NVR to my network. I basically treat it like a DVR.
Help!
I really want to get this ColorVu camera working because I assist the local PD with footage a few times per year, due to my house being on a major street.When I click the triangle button to see what the issue is, it always says "Disconnected" and that's it. Sometimes, the serial number will become visible as I play with the IP address, but the camera view never shows up. Hikvision support doesn't believe me that the triangle only says "Disconnected", and they want me to give them the rest of the error message. I haven't been connecting my NVR to my network. I basically treat it like a DVR.
Help!
