I've been using a VPN service to enhance my online security and privacy. Normally, I connect to the VPN without any issues using my wired connection. However, when I switch to WiFi and try to establish a VPN connection, I run into problems. The connection either takes forever to establish or it doesn't connect at all. This happens regardless of the WiFi network I'm using, whether it's my home network Licenses Renewal DMVNOW or a public hotspot. Has anyone else experienced a similar problem where connecting to a VPN through WiFi is a lot trickier than through a wired connection? I'm wondering if there's something about WiFi settings that might be causing this. Maybe there's a port or protocol that needs to be open for the VPN to work seamlessly over WiFi? Or could there be some interference or compatibility issues between the VPN software and WiFi networks?
