Since I started to try and use tripwire Ive noticed it stops working, by working I mean tracking objects. I have not been able to figure out why yet, at first I thought it was after the NVR went through a reboot, possibly overwriting the cameras setting, but that wasn't it. Right not I'm just thinking possibly random, or after a period of time.
Doing anything with the camera seems to restart it (like logging in and oing to settings, or even moving the camera seems to), though it's hard to tell when exactly it stops and starts.
Anyone had this problem?
SD59230U-HNI
NVR5432-4KS2
**solution**
FYI, for anyone that has the same problem. I have "solved" this by having the camera reboot daily immediately following the NVRs daily reboot. I'm not sure if just daily reboots are what fixed it, or specifically being after the NVR. I suspected it could be either intermittent loss after the NVR rebooted, or it was just random time based, eventually crapped out.
SD59230U-HNI
NVR5432-4KS2
**solution**
