I am new to Blue Iris and I think it's great! It's easy to get started but there is lot's of depth,-and to learn.
So I have been experimenting with different Record setting for my single PZT x4 Zoom IR equipped Logisaf (Chinese knockoff) camera. I am running on a Xenon 3.3GHz Server 2012R2. (A bit bummed the CPU utilization is 70%+ !!!)
If I go to Camera>Record>Video>Triggered+Periodic to create a combination timelapse+trigger video I can & have set the period to 1 min intervals plus both a 0 sec duration and 0.1 sec duration. The difference is substantial.
Using the horizontal timeline to play the video results in a series of "flashes" for each 1 minute interval shot as if a flash had gone off when using the 0.1 second record time; this is for night time shots where I am not using the IR feature as there is enough illumination from conventional sources. However, the resulting combined video (using BVR) looks perfect. I assumed my camera needed some adjustment, but the video looked OK so no worries.
However if I set the record period to zero instead of 0.1 second the flashes disappear and both the timeline video and the finished assembled video (from the right hand vertical window) look perfect.
I suppose this is a bit of a tempest in a teapot, but just wondering if a camera adjustment is in order or I have something else out of kilter. I have not been using IR at night as everything collapses to B&W (of course).
