I like having all my camera's trigger settings syncronized to 1 camera (much easier than making a change to each one), but I need to have each camere use a differently defined motion zone.
My understanding of the "sync" feature is that the the "slave" cameras use the same triggering settings (threshold levels and types/approached) as the "master" does to determine when to trigger. That is, the "sync" facility does NOT mean that the "slave" cameras are triggered at the same time as the "master" is triggered. This is correct?
Is it possible to have each camera use its own motion detection zone while still having the trigger tab sync'd?
If not, what does everyone do? Set up each camera's trigger section separately?
Thank you.
Thank you.
