The icon indicates a trigger state. Are you saying that it appears even when the camera is not being triggered?I've noticed that possibly upgrading to the latest version, on each camera the red warning triangle is showing. If you simply single clikc onto each camera, the triangle vanishes. Has anybody else experienced this?
The icon will stay on as long as the camera is in a trigger state, so if your trigger end time is 30 seconds it will stay on for 30 seconds even of no other trigger event is present.I'm not sure - I'd need to check.
I suspect what might be happening is that the software has correctly sensed motion and the trigger icon is staying on.
Yep. A camera has just gone into trigger state now. Let's see how long it stays on for.
There may have been another trigger during the 15 second break time. I dont know why it would stop when clicking on the camera. Do you have BI set to put a red boarder around the camera when recording? if so does that go away too?The break time is 15 seconds and even after motion has ceased and the 15 seconds has elapsed, the trigger icon is still on. If I click onto the camera, the trigger icon goes away.
Is the triangle next to the red circular record icon?
I see the same issue. Send an email to support.1. I do not think there has been another trigger.
2. Yes, there is a red border around the camera when it records and this goes away when recording ceases.
3. Yes, the triangle is to the left of the red circular record icon.
Just this forum. This forum and I are not associated with BI in any way.Great.
Out of interest, are you associated with BI or do you just run a forum?
