Having an issue where recording just stops in the middle of action.
Have my "Make" time set to 0.0
Have my "Break" time set to 20
I am attaching a video clip demonstrating my dilemma.
In the clip, you'll see garbage men loading the back of the truck, lots of movement, and
immediately, it's just the truck pulling away.
Even though there was constant movement, (which should have kept resetting the trigger),
it didn't. The recording just stopped while the guys were loading the back of the truck, and
then resumed again after they were in the truck, taking off.
I was under the assumption, that, as long as there is movement, the trigger is getting reset, and
if all movement stops, the recording will continue for Break Time.
Mines not working that way.
Love the software though, any help?
