Hi,
has anyone experience with the TrendNet TV-NVR416? We are searching for our company a replacement NVR (old one has no brand and only 4ch) I know it has only 1 Monitor output (no independent use of hdmi and vga) but thought to use the "Mira" app of them on an android stick on a second monitor. Anyone using this app? Tried with the TrendNet support/sales but nothing than standard phrases/ nothing helpful at all. As always it should be as cheap as possible due to we are a startup and therefore limited. Use case: we have 3 cams (KKmoon/no brand) installed and need 6 more atm (and maybe even more later) - 16cams on one screen is to much so what do you think about the "app" solution? Tried to find a dual output one but they are quite expensive here - any hint? Thought also to buy some Reolinks RCL-410 (yes i know they are quite notorious here) but they are affordable and fast to get here in Germany. Quality should be enough. Any other hint in this? Budget is ~120$/80€ each
Hope for some constructive and useful input!
Thanks and cheers,
Max
Thanks and cheers,
Max
