Hi, my Name is Björn from Germany.
I have 20 Trendnet Tv IP319PI (8mp - 4K) Cam‘s and about 10 Hikvision DS-2CD2183G0-I.
All Connectet to a new Hikvision NVR.
The Hikvision NVR Recognises the Trendnet Cam‘s. On the NVR Display, only the Mainstream works. The Substream show‘s „unsupportet Format“.
At the Web Interface from the NVR - everythings fine.
Is there a way to bring a Hikvision Firmware to the Trendnet Cam‘s? Wich One fit‘s?Because, many Features of the Hik NVR won‘t work with the Trendnet Cam, Including the Substream.
Or a Setup workarraound?
The Spec‘s and the whole Cam are optical the Same as the Hikvision DS-2CD2183G0-I.
I know, in the past many Trendnet Cam‘s are the same as the Hikvision and some Hikvision firmware‘s fit‘s direct to the Trendnet Cam‘s.
Thank you, for your Support!
