Hi everyone,
I have a camera that I need to access single shot image captures from, I have many other TrendNet & HikVision cameras and the following url works great:
- but on this TV-IP317PI, its just not working, its returning this message:
Access Error: 405 -- Method Not Allowed
Requested method GET not supported for URL: /Streaming/channels/1/picture
I've followed the instructions in the previous post below
ipcamtalk.com
And it seems is returning a success 200 OK code, but still the link above doesn't work. I'd even consider replacing its firmware with HikVision FW if it was possible, but I can'e even enable SSH to check cpu info either - theres no option for it in the TrendNet firmware....
Other wise the camera is working fine, but not in the way I need it to.
Have any of you overcome this problem before?
Thanks!
Sean
Hikvision DS-4420IW-D - no URL access (error 405 no access)
Hi all, I tried to open the video/picture streams via URL (xxx.xxx.xxx.xxx/streaming/channels/1/picture). However I get an 405 Access error. I checked the config but no special switch found to turn the URL access on. I have around 10 Hikvision cams - all work except the newest one. I running...
Thanks!
Sean
