Dear ip-cammers,
I've tested my DS-2CD2032-I and used the iVMS-4200 software under Windows 10 and the iVMS-4500 under Android. The cam saves the recordings on a SAMBA mount on my Synology NAS.
I tested the setup when the CAM was linked in my local network. I was suprised to find that playback behaved quite fast and all in all was experiencing a responsive behavior.
I now have my cam hooked up to my garage linked to my network via a powerline. It's not the fastest one around, I tested it bandwidth to be approx 20Mbit. So i setup my streams to max 6Mbit since I thought that would help if I would like to view a live-feed while the cam is recording simultaneously. This works reasonable, quite a bit slower as compared to local network but bearable.
Now the problem. When I use remote playback using Windows or Android it used to be quite fast, searching and playing new clips was quite fast. But now it's laggy.
Is it correct to draw the conclusion that the remote playback stream is offered by the camera itself and not offered directly? In my case, I'd rather have it stream directly to my NAS since that is hooked up using gigabit. When the stream goes via the IP-cam, it has to use the meager 20Mbit connection which might be insufficient.
Is my conclusion correct? And if so, is there anything I can do to improve the user experience with the iVMS-4200/4500?
