For the longest time I had an older version of BI5, running behind Traefik reverse proxy. No issues running it this way for over a year.
I decided to move BI to new hardware, Same OS and IP. Exported the old settings and imported to the new computer. Only thing that was a little weird with that was ran into the "unable to delete import key" fixed that by giving permissions to the a1 reg key.
After moving everything over I get a Bad Gateway error when going through the reverse proxy. If I use the ip address no issues. I saw there were some issues with an older version, so I decided to upgrade to the last stable.
Since than I get an error like 50% of the time. What usually happens is I can connect then after a little while I get video stream lost and the 502 error, I can just leave it sit and then it will reconnect and continue the cycle.
Like I said connecting by IP works fine, it's been driving me nuts for days now.
Thanks in advance!
Thanks in advance!
