J jphump n3wb Nov 6, 2017 5 0 Nov 25, 2017 #1 Is this an acceptable switch for a BI system starting with 8 cameras? TP-LINK - 24-Port 10/100/1000 Mbps Gigabit Ethernet Switch - Gray
fenderman Staff member Mar 9, 2014 36,891 21,408 Nov 25, 2017 #2 jphump said: Is this an acceptable switch for a BI system starting with 8 cameras? TP-LINK - 24-Port 10/100/1000 Mbps Gigabit Ethernet Switch - Gray Click to expand... If cams are poe you want a Poe switch
J jphump n3wb Nov 6, 2017 5 0 Nov 25, 2017 #3 They are POE, and if I'm reading the specs right, this is a POE switch. Number of PoE (Power over Ethernet) Ports 24 Wattage per PoE (Power over Ethernet) Port 13.1 watts Form Factor Rack mountable (mount kit included) Maximum Data Speed 1000 megabits per second Switch Management Type Unmanaged Number of LAN Ports 24 "
Philip Gonzales Getting comfortable Sep 20, 2017 696 554 Nov 25, 2017 #4 jphump said: They are POE, and if I'm reading the specs right, this is a POE switch. Number of PoE (Power over Ethernet) Ports 24 Wattage per PoE (Power over Ethernet) Port 13.1 watts Form Factor Rack mountable (mount kit included) Maximum Data Speed 1000 megabits per second Switch Management Type Unmanaged Number of LAN Ports 24 " Click to expand... I think the specs are wrong. If you Google the model number none of the other sites mention PoE. Reactions: fenderman
