fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,417
Fool, why are you lying? BEFORE running your mouth and making FALSE accusations why dont you FUCKING TEST IT YOURSELF!!!!I will tell everyone what happened later, but for right now I hope the creators read this.
I open the OUTSIDE ACCESS by clicking a little box (enable the HTTP web server in the Web server tab), and the software CREATES AN anonymous user (UNKNOWN TO ME, THE BI USER!!) that requires ZERO credentials, not even required to enter a user name!!! ??? Who in their right mind decided this was a good idea??? forget around you should read the manual... this is SUPER STUPID and I doubt anyone would WANT THIS!!! Why would it create a user without your knowledge and let alone create one anyway and no credentials at all on top of that!! ?
the local_console user created to not need a password... I unchecked it, and I can still get in locally without a password in the local account!!! Why? I have unchecked as enabled, but it still works!
I reopened the port just to see what happens when I put in my public ip as some have suggested, my whole system just pops up as if I logged in... WHY?? HOW?? So I go into the users tab and see that the software recreated the anonymous user THAT I DELETED because I clicked a little box and that's why it just popped up like that. I mean it JUST POPPED UP, my WHOLE SYSTEM!!! never asked for a user name or ANYTHING!! again, who in their right mind thought an end user would want this????
so just by opening a port for my use the software (without letting me know... yeah yeah read the manual) created a user that requires nothing..... upon doing so without me knowing allowed anyone in the world to just have at it and that's how they got in.
you guys can get mad at me if you want... this is just super stupid and I consider this a major flaw and it should be removed to auto create a user like that. Thank you everyone for your help in this matter.
FROM THE HELP FILE
"The local_console user is created automatically and is used only locally when you open the
software. There are ways to login locally using another account in order to limit access,
discussed in the Administration chapter{
"The user local_console is automatically created whenever you connect via the console (the PC
running Blue Iris). It is not possible to use this account remotely so that it cannot pose a
security threat."
MOST IMPORTANTLY, IF YOU DONT SET A PASSWORD FOR THESE ACCOUNTS YOU CANNOT ACCESS THEM EVEN LOCALLY. In fact, I just tested it and it wont allow access locally even if you did set a password. You are just a fucking idiot.
THE ONLY WAY that someone would have access as you described would be if YOU, like the fool you are, disabled authentication in the webserver advanced tab. So its not blue iris that is "super stupid" is it?
You know just enough about networking and blue iris to make stupid assumptions and false accusations.
