Each sunrise and sunset my cameras motion alarms trigger like crazy when the IR lights for my camera turn on and off. When you have 16 cameras it can get a bit wild and annoying especially when your cameras cycle the IR on and off several times when the light is just enough for IR off or ON and the camera isn't sure which one to stick with. The lighting area is huge so decreasing the sensitivity via object size doesn't seem to do the trick.
Any other tips & tricks I should try?
