Setup completed as per guidelines and user/pw used are the same used in the Wyze app account on the iPhone. Cams stream flawlessly on iPhone.
I'm getting no feed from the cam on tinyCam, instead I get the 2fa two verification code required pop up which makes no sense as I do not use that additional security step. I believe the problem can be seen in the Camera Status info within TC:
As you can see in Advanced Info it says P2P Mode - P2P. From everything I've seen on other set up examples it should say P2P Mode - LAN. Now if I Scan Network the cam will show up but just with it's IP number and an alpha numeric designation under it starting with P2Pxxxxxxxxxxxxx. So in my mind, TC sees a cam but not as a Wyze cam.
I'm missing something but I cannot think of what it is. Paging Alex......please pick up the Courtesy Phone
