I currently run 30 Foscam cameras (480p) and a couple Dhaua cameras (720p) and have had issues with cameras dropping their signal in Blue Iris. I am finding it difficult to narrow down the cause. I used to have multiple computers, each running Blue Iris to spread the cameras out (6 on each box), because they were older computers. Then I decided to build a very powerful computer and am finding I need to run 25 to not worry about them dropping a signal on me.
Specs
- Intel Core i7 4790 4 GHz
- 8 GB RAM
- 512 GB SSD main drive
- 32 TB storage
- Windows 10 Pro
I have seen theories (cheap Foscam cameras, bandwidth, disk drive write bandwidth, Blue Iris, etc) but it's very hard to troubleshoot the cause.
So my question is, if I invest in a NVR, like a Dhaua with 32 channels, will I need to be concerned about this happening?
https://www.bhphotovideo.com/c/product/1264383-REG/dahua_technology_dhi_nvr6a08_32_4ks2_32_channel_nvr_8sata.html
I am looking at 24/7 recording, around 7-10 FPS at 720p max.
Also, will the Dhaua recognize other camera brands such as the Foscam until I can get those replaced with more Dhaua's?
My other option is to just build a second computer like the one above and offload cameras to it like I was doing in the past.
Specs
- 8 GB RAM
- 32 TB storage
- Windows 10 Pro
