I have a few Hikvision DS-2CD2042WD-I cameras where the time is off by an hour. I set the timezone correctly, configured NTP, DST is disabled, and for some reason it's still behind by one hour.
I don't know if it's a bug in the firmware or what to do. Any ideas?
Firmware: V5.3.8 build 151224
Edit:
I just discovered a possible workaround. I switched to manual time sync, fixed the time, checked the "sync time with computer" box and saved. The time is now correct. Then I switched back to NTP and saved again.
I'm not too confident that the camera is actually respecting the NTP time since it didn't before, but... oh well.
Edit:
