Hey everyone, I've put together a system and have been tinkering with it prior to expanding and wanted to get your thoughts (and prayers) and advice.
I've picked up a Dell PowerEdge R720 with ESXi 6.7 running a couple VM's (BI & DNS/DHCP). I added 8 x 4TB WD Gold disks to give me a RAID 5 capacity of just over 25TB.
I created a BI server and applied 8 CPU's, 16GB RAM, and an initial data drive of 10TB, expandable to 23TB if I need it. So far, I'm only up to 2.5TB and that has me thinking I overkilled it a bit.
I'm wondering if I should've just gone with a 16-channel NVR with 2x6TB drives and called it a day.
It would've been a bit cheaper and not make as much noise, I think. It generates a bit of heat and I have it in a closet. Because of the enclosed space, I had to install a vent system for it and it seems to be working fairly well.
I am totally open to dumping it in favor of an NVR, I just won't have the storage capacity. Maybe 2 weeks vs 4 weeks. What are your thoughts?
I purchased 3 different cameras to test (IPC-T2431T-AS – 2.8mm, IP8M-T2499EW-28MM, IPC-T2231T-ZS), so I'm not generating a lot of bandwidth yet. Ultimately, I plan on running a total of 11, possibly 12. This should generate about 670GB/day at 30 FPS.
I had planned on using 5 8MP cameras because the areas are mostly well lit at night. Looking at BW and reality, am planning on going with mostly 4MP cameras because they should give me good quality and they cost less as well as generate lower storage totals. Plus, the model I was testing (IPC-T2431T-AS – 2.8mm) has audio and I found it helpful.
So my final planned setup, IF I can find the $84 4MP cameras in black is as follows:
1 x 2MP <-- Really good night vision
9 x 4MP - Hopefully 5 in black.
1x 8MP - front door, already installed.
I really don't want to paint cameras. That never holds up over time. If your experience varies, please let me know how you did it. I'm in Florida and it gets hot and humid as balls (industry term).
I was having issues with not getting 24/7 recording and have yet to see how to change that using BI controls. I did modify the cameras themselves by going to the record schedule and selecting General, then all days and periods. I do seem to be getting much bigger files now, but I thought BI would have that kind of control. Anyone care to point me in the right direction?
The 4MP cameras I chose (IPC-T2431T-AS – 2.8mm) are $84/ea. I was looking for that model in black so the camera will blend into the background better. Unfortunately, I haven't found them and the only ones I found so far (IPCT-2X4G-DM – Black ) cost $135. That's $250 extra, and I'd like to avoid that extra cost. Anyone know if the $84 model comes in black? I haven't seen it.
Am I being silly to hold out for a less expensive black turret model?
I really wanted to purchase through this site because I know it helps them out.
Thanks for looking, I appreciate your input.
