- Jun 22, 2016
- 195
- 15
Morning All –
Background
I’m moving back to my home and wanted to take advantage to start with securing my home network. Gear is 7 POE IP cameras run with Blue Iris, Wifi/ZWave Locks/Doorbells, Always on PCs AND I’m adding Home Assistant (most likely with w Raspberry Pi5) . In past I didn’t have much security setup and used Blue Iris wizard for port forwarding etc – but not sure I want to do that moving forward as i'm trying to avoid port forwarding and firewall exceptions.
Wants
Thanks in advance for any advice.
Happy Sunday!
Background
Wants
- Easy>Moderate Secure home network, I’m fairly tech savvy but don’t want to mess with VLANs. Many have recommend Tailscale and/or OpenVPN
- Separate Guest WiFi so they can’t access network – Think I can do that fairly easily with built in Router/Access Point setup
- When sitters are in the home network – have them able to access the cameras (I’ve don’t that before w/ Blue Iris user name)
- Easy access for wifey when she wants to view camera while outside the home network.
- ** For those that use home automation/Home Assistant or similar – I would like to still be able to utilize Geofencing in scenes and not have to “click on a VPN” is that possible?
- ?QUESTION? - Will setting up VPN/Tailscale compromise data speed?
Happy Sunday!
