Webfont Pulling my weight Sep 6, 2018 140 181 Canada Feb 5, 2025 #1 I wanted to try the newer S3 models, and came across this one used on amazon for a good discount, so I bought it. But nowhere does it say S3 on the model tag. That's just the normal older S2, right? Attachments IMG_0039 - Copy.JPEG 333.7 KB · Views: 0
wittaj IPCT Contributor Apr 28, 2019 30,849 59,196 USA Feb 5, 2025 #2 Given the date, nope it isn't. You will know for sure by the GUI - if it is white/blue it is S3, if it is grey/black/orange it is older. Reactions: JDreaming, Parley, mat200 and 1 other person
T tigerwillow1 Known around here Jul 18, 2016 4,734 10,769 USA, Oregon Feb 5, 2025 #3 wittaj said: You will know for sure by the GUI Click to expand... And also by the mounting base. The S3 has the bigger diameter snap-in base, the old one the clamshell with the torx screw. S2 on the left, S3 on the right. Reactions: JDreaming, Parley, mat200 and 2 others
Webfont Pulling my weight Sep 6, 2018 140 181 Canada Feb 5, 2025 #4 I definitely got an S2 then. Its's going back to amazon Thanks guys,
T tigerwillow1 Known around here Jul 18, 2016 4,734 10,769 USA, Oregon Feb 5, 2025 #5 As an added note, only the fixed focal S3s have the new mounting base. The S3 varifocal still has the old type base. Reactions: JDreaming and jrbeddow
