Hi, i want to list some points, which are very annoying - frustrating for me. It might be that i might be wrong, if so please let me know / advice
- On remote, you cannot LOCK file, like you can on gui interface ( in order to backup them later )
- When device is added to cloud ( hik connect ) and you want to download a period of 1 hour, its only giving 2 mins.. which can take very long time, especcialy with multiple camera views
- No Possibility to download clips larger then 2 MINS on mobile
- When downloading footage from WEB, you cannot only download a specifik period of time, it gives you the whole footage, also before and after. ( While you CAN with IVMS )
- When you are on Remote, you cannot access the webpages of ip cameras, which are connected to POE switch ( unless you do portforwarding to them , 1 by 1 )
- When you have a ip camera with build in mic, its not possible to give someone only acces to video, without audio. No user restrictions
- When by example acusense /speaker / light camera is connected , you cannot control this one, unless you add it to the cloud ( with portforwarding the functions are not available )
