I'm a novice BI user. BI moves files from NEW to STORED with a minimum interval of 1 hour or a minimum size of 1GB. Assume STORED is in a different location (room, remote NAS, geo address) than NEW. I think this means: the files for the current NEW processing time interval or xGBs are not captured at the STORED location. So, if the BI device is stolen or destroyed that data is not available. It is likely that the last 1 hour/GB is needed in such an event. Further, the size for NEW and the time interval used (if any) are likely much larger than the minimum. Is there a BI solution for this issue?
My current approach is to use the pCloud backup feature for the NEW folder to get near real-time backup of NEW and I do not 'like' this solution since it depends on an additional program.
I'm looking for other ideas on how to address this problem.
