The imou cruiser triple will restart.
banv1194
May 2, 2024
3
1
japan
If I create three ONVIF settings for the Imou Cruiser Triple in the app and access them simultaneously in multi-view, the camera restarts.
I could understand if only the Triple restarted, but other cameras connected to the network also restart at the same time.
It is possible to create just one setting and then select profiles in multi-view to display three screens.
Since a similar issue occurs with IP Cam Viewer, I suspect the Triple has an upper limit on the number of ONVIF requests it can handle. I own four different types of Imou cameras, but this issue only happens with the Triple.
Is this a recent specification of the Cruiser?
