# cat /proc/kmsg
<6>[ 0.000000] Booting Linux on physical CPU 0
<6>[ 0.000000] Initializing cgroup subsys cpu
<5>[ 0.000000] Linux version 3.4.35 (huangliangyf2@Cpl-Frt-BSP) (gcc version 4.8.3 20131202 (prerelease) (Hisilicon_v300) ) #1 Thu May 14 15:33:35 CST 2015
<4>[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
<4>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<4>[ 0.000000] Machine: g0
<7>[ 0.000000] MISC TAGS: mdio_intf=mii phy_addr=3
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writeback
<7>[ 0.000000] On node 0 totalpages: 26112
<7>[ 0.000000] free_area_init_node: node 0, pgdat c06e1a98, node_mem_map c0737000
<7>[ 0.000000] Normal zone: 204 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 25908 pages, LIFO batch:7
<7>[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
<7>[ 0.000000] pcpu-alloc: [0] 0
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 25908
<5>[ 0.000000] Kernel command line: console=ttyAMA0,115200
<6>[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
<6>[ 0.000000] Memory: 102MB = 102MB total
<5>[ 0.000000] Memory: 96084k/96084k available, 8364k reserved, 0K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xc6800000 - 0xff000000 ( 904 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xc6600000 ( 102 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc04fd000 (5076 kB)
<5>[ 0.000000] .init : 0xc04fd000 - 0xc06ab8f4 (1723 kB)
<5>[ 0.000000] .data : 0xc06ac000 - 0xc06e21c0 ( 217 kB)
<5>[ 0.000000] .bss : 0xc06e21e4 - 0xc0736ee0 ( 340 kB)
<6>[ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
<6>[ 0.000000] NR_IRQS:128
<6>[ 0.000000] sched_clock: 32 bits at 49MHz, resolution 20ns, wraps every 86767ms
<6>[ 0.000000] Console: colour dummy device 80x30
<6>[ 0.000129] Calibrating delay loop... 1196.85 BogoMIPS (lpj=5984256)
<6>[ 0.090076] pid_max: default: 32768 minimum: 301
<0>[ 1.548939] Card authentication succeeded
<6>[ 1.549095] Mount-cache hash table entries: 512
<6>[ 1.549658] Initializing cgroup subsys freezer
<6>[ 1.549759] CPU: Testing write buffer coherency: ok
<6>[ 1.549977] Setting up static identity map for 0x803cd7e0 - 0x803cd838
<6>[ 1.552416] dummy:
<6>[ 1.552834] NET: Registered protocol family 16
<6>[ 1.555388] Serial: AMBA PL011 UART driver
<6>[ 1.555487] uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 40) is a PL011 rev2
<6>[ 1.555568] console [ttyAMA0] enabled
<6>[ 1.555937] uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 41) is a PL011 rev2
<6>[ 1.556279] uart:2: ttyAMA2 at MMIO 0x200a0000 (irq = 42) is a PL011 rev2
<6>[ 1.579137] bio: create slab <bio-0> at 0
<6>[ 1.579933] gpiochip_add: registered GPIOs 0 to 127 on device: r7-gpio
<5>[ 1.581470] SCSI subsystem initialized
<5>[ 1.581490] hi_spi_init->776:
<5>[ 1.581500] compile time:May 14 2015 15:33:19
<5>[ 1.581720] hi_spi_init->784:
<5>[ 1.581730]
<5>[ 1.581738] hi_spi_set_platdata->160:
<5>[ 1.581746]
<5>[ 1.581754] hi_spi_set_platdata->160:
<5>[ 1.581762]
<5>[ 1.582026] hi_spi_probe->590:
<5>[ 1.582036]
<5>[ 1.582055] hi3516a_spi_hw_init_cfg->105:
<5>[ 1.582063]
<5>[ 1.582360] hi-spi-master hi-spi-master.0: with 1 chip select slaves attached
<5>[ 1.582646] hi_spi_probe->590:
<5>[ 1.582655]
<5>[ 1.582673] hi3516a_spi_hw_init_cfg->105:
<5>[ 1.582682]
<5>[ 1.582984] hi-spi-master hi-spi-master.1: with 3 chip select slaves attached
<6>[ 1.584008] usbcore: registered new interface driver usbfs
<6>[ 1.584443] usbcore: registered new interface driver hub
<6>[ 1.584702] usbcore: registered new device driver usb
<6>[ 1.587209] Switching to clocksource timer0
<6>[ 1.604813] NET: Registered protocol family 2
<6>[ 1.605075] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
<6>[ 1.605542] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 1.605668] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
<6>[ 1.605741] TCP: Hash tables configured (established 4096 bind 4096)
<6>[ 1.605754] TCP: reno registered
<6>[ 1.605769] UDP hash table entries: 256 (order: 0, 4096 bytes)
<6>[ 1.605798] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
<6>[ 1.606103] NET: Registered protocol family 1
<6>[ 1.606425] RPC: Registered named UNIX socket transport module.
<6>[ 1.606443] RPC: Registered udp transport module.
<6>[ 1.606454] RPC: Registered tcp transport module.
<6>[ 1.606464] RPC: Registered tcp NFSv4.1 backchannel transport module.
<4>[ 1.791268] mmc0 power register success!
<4>[ 1.791291] mmc1 power register success!
<5>[ 1.811685] VFS: Disk quotas dquot_6.5.2
<4>[ 1.812189] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
<5>[ 1.813221] NFS: Registering the id_resolver key type
<6>[ 1.814386] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
<6>[ 1.815525] fuse init (API version 7.18)
<7>[ 1.817061] yaffs: yaffs built May 14 2015 15:32:51 Installing.
<6>[ 1.817123] msgmni has been set to 187
<6>[ 1.819430] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
<6>[ 1.819454] io scheduler noop registered
<6>[ 1.819466] io scheduler deadline registered (default)
<6>[ 1.819524] io scheduler cfq registered
<6>[ 1.831476] brd: module loaded
<6>[ 1.837434] loop: module loaded
<6>[ 1.839425] Spi id table Version 1.22
<7>[ 1.839441] Hisfc350 Device Driver, Version 1.10
<5>[ 1.840086] Found Nand Flash Controller V610.
<4>[ 1.840725] Nand ID: 0x98 0xF1 0x80 0x15 0xF2 0x16 0x08 0x00
<4>[ 1.840751] #########[ECC] pagetype 2, ecctype 3
<4>[ 1.840781] Nand: Toshiba TC58BVG0S3HTA00
<4>[ 1.840793] Nand(HW-Auto): Block:128KB Page:2KB OOB:64B ECC:4bit/512 Chip:128MB*1
<5>[ 1.843533] Creating 13 MTD partitions on "hinand":
<5>[ 1.843560] 0x000000000000-0x000000100000 : "bld"
<5>[ 1.849496] 0x000000100000-0x000000180000 : "env"
<5>[ 1.853658] 0x000000180000-0x000000200000 : "enc"
<5>[ 1.857778] 0x000000200000-0x000000280000 : "sysflg"
<5>[ 1.861800] 0x000000280000-0x000000380000 : "dpt"
<5>[ 1.867460] 0x000000380000-0x000000b80000 : "sys0"
<5>[ 1.896464] 0x000000b80000-0x000001380000 : "sys1"
<5>[ 1.925485] 0x000001380000-0x000003980000 : "app0"
<5>[ 2.054248] 0x000003980000-0x000005f80000 : "app1"
<5>[ 2.182988] 0x000005f80000-0x000006380000 : "cfg0"
<5>[ 2.198204] 0x000006380000-0x000006780000 : "cfg1"
<5>[ 2.213863] 0x000006780000-0x000007780000 : "syslog"
<5>[ 2.269389] 0x000007780000-0x000008000000 : "resv"
<5>[ 2.300583] hi_spi_setup->427:
<5>[ 2.300596]
<5>[ 2.301140] hi_spi_setup->427:
<5>[ 2.301152]
<5>[ 2.301692] hi_spi_setup->427:
<5>[ 2.301704]
<5>[ 2.302215] hi_spi_setup->427:
<5>[ 2.302225]
<6>[ 2.302766] tun: Universal TUN/TAP device driver, 1.6
<6>[ 2.302780] tun: (C) 1999-2004 Max Krasnyansky <
[email protected]>
<6>[ 2.303873] Higmac dma_sg_phy: 0x85ac0000
<6>[ 2.397158] higmac_mdio_bus: probed
<6>[ 2.398854] ETH0: mii, phy_addr=3, mii_name=mdio0
<6>[ 2.398871] PPP generic driver version 2.4.2
<6>[ 2.399396] PPP Deflate Compression module registered
<6>[ 2.404684] PPP MPPE Compression module registered
<6>[ 2.404706] NET: Registered protocol family 24
<6>[ 2.405186] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
<6>[ 2.431103] hiusb-ehci hiusb-ehci.0: HIUSB EHCI
<6>[ 2.431201] hiusb-ehci hiusb-ehci.0: new USB bus registered, assigned bus number 1
<6>[ 2.431311] hiusb-ehci hiusb-ehci.0: irq 53, io mem 0x100b0000
<6>[ 2.450062] hiusb-ehci hiusb-ehci.0: USB 0.0 started, EHCI 1.00
<6>[ 2.451189] hub 1-0:1.0: USB hub found
<6>[ 2.451225] hub 1-0:1.0: 1 port detected
<6>[ 2.451980] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
<6>[ 2.452319] hiusb-ohci hiusb-ohci.0: HIUSB OHCI
<6>[ 2.452382] hiusb-ohci hiusb-ohci.0: new USB bus registered, assigned bus number 2
<6>[ 2.452430] hiusb-ohci hiusb-ohci.0: irq 54, io mem 0x100a0000
<6>[ 2.515109] hub 2-0:1.0: USB hub found
<6>[ 2.515144] hub 2-0:1.0: 1 port detected
<6>[ 2.515895] Initializing USB Mass Storage driver...
<6>[ 2.516239] usbcore: registered new interface driver usb-storage
<6>[ 2.516255] USB Mass Storage support registered.
<6>[ 2.516824] mousedev: PS/2 mouse device common for all mice
<6>[ 2.550677] rtc rtc: rtc core: registered rtc as rtc0
<6>[ 2.551173] i2c /dev entries driver
<5>[ 2.552722] hisi_i2c hisi_i2c.0: Hisilicon [i2c-0] probed!
<5>[ 2.553281] hisi_i2c hisi_i2c.1: Hisilicon [i2c-1] probed!
<5>[ 2.553830] hisi_i2c hisi_i2c.2: Hisilicon [i2c-2] probed!
<6>[ 2.554269] r7 watchdog driver v1.0. initial timeout 60 sec
<6>[ 2.556698] card disconnected!
<6>[ 2.558015] card disconnected!
<6>[ 2.559182] usbcore: registered new interface driver usbhid
<6>[ 2.559198] usbhid: USB HID core driver
<6>[ 2.559296] Netfilter messages via NETLINK v0.30.
<6>[ 2.559321] nfnl_acct: registering with nfnetlink.
<6>[ 2.559408] nf_conntrack version 0.5.0 (1501 buckets, 6004 max)
<6>[ 2.560971] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 2.561101] TCP: cubic registered
<6>[ 2.561113] Initializing XFRM netlink socket
<6>[ 2.563147] NET: Registered protocol family 10
<6>[ 2.564320] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 2.564401] IPv6 over IPv4 tunneling driver
<6>[ 2.566804] NET: Registered protocol family 17
<6>[ 2.566861] NET: Registered protocol family 15
<6>[ 2.566921] lib80211: common routines for IEEE802.11 drivers
<7>[ 2.566935] lib80211_crypt: registered algorithm 'NULL'
<5>[ 2.566948] Registering the dns_resolver key type
<6>[ 2.567072] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
<6>[ 2.568113] registered taskstats version 1
<6>[ 2.600094] rtc rtc: setting system clock to 2015-07-22 11:43:24 UTC (1437565404)
<6>[ 2.602983] Freeing init memory: 1720K
<6>[ 3.388288] yaffs: dev is 32505863 name is "mtdblock7" rw
<6>[ 3.388306] yaffs: passed flags ""
<7>[ 3.388320] yaffs: yaffs: Attempting MTD mount of 31.7,"mtdblock7"
<7>[ 3.388649] yaffs: checking block 0 bad
<7>[ 3.392627] yaffs: yaffs_read_super: is_checkpointed 1
<6>[ 3.435435] ADDRCONF(NETDEV_UP): eth0: link is not ready
<6>[ 5.410274] PHY: mdio0:03 - Link is Up - 100/Full
<6>[ 5.410402] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
<6>[ 7.400547] yaffs: dev is 32505865 name is "mtdblock9" rw
<6>[ 7.400565] yaffs: passed flags ""
<7>[ 7.400580] yaffs: yaffs: Attempting MTD mount of 31.9,"mtdblock9"
<7>[ 7.407454] yaffs: checking block 0 bad
<7>[ 7.407681] yaffs: block 1 is bad
<7>[ 7.407690] yaffs: checking block 1 bad
<7>[ 7.408330] yaffs: checking block 2 bad
<7>[ 7.408549] yaffs: block 3 is bad
<7>[ 7.408558] yaffs: checking block 3 bad
<7>[ 7.409195] yaffs: checking block 4 bad
<7>[ 7.409431] yaffs: block 5 is bad
<7>[ 7.409440] yaffs: checking block 5 bad
<7>[ 7.410279] yaffs: checking block 6 bad
<7>[ 7.410924] yaffs: checking block 7 bad
<7>[ 7.411562] yaffs: checking block 8 bad
<7>[ 7.412198] yaffs: checking block 9 bad
<7>[ 7.412834] yaffs: checking block 10 bad
<7>[ 7.413471] yaffs: checking block 11 bad
<7>[ 7.414107] yaffs: checking block 12 bad
<7>[ 7.414742] yaffs: checking block 13 bad
<7>[ 7.415378] yaffs: checking block 14 bad
<7>[ 7.416014] yaffs: checking block 15 bad
<7>[ 7.416649] yaffs: checking block 16 bad
<7>[ 7.417285] yaffs: checking block 17 bad
<7>[ 7.417921] yaffs: checking block 18 bad
<7>[ 7.418557] yaffs: checking block 19 bad
<7>[ 7.419193] yaffs: checking block 20 bad
<7>[ 7.419829] yaffs: checking block 21 bad
<7>[ 7.420490] yaffs: checking block 22 bad
<7>[ 7.421128] yaffs: checking block 23 bad
<7>[ 7.421765] yaffs: checking block 24 bad
<7>[ 7.422401] yaffs: checking block 25 bad
<7>[ 7.423036] yaffs: checking block 26 bad
<7>[ 7.423672] yaffs: checking block 27 bad
<7>[ 7.424308] yaffs: checking block 28 bad
<7>[ 7.424944] yaffs: checking block 29 bad
<7>[ 7.425579] yaffs: checking block 30 bad
<7>[ 7.426215] yaffs: checking block 31 bad
<7>[ 7.443570] yaffs: yaffs_read_super: is_checkpointed 0
<6>[ 8.160948] base module init version.
<4>[ 8.168121] hikcomm: module license 'Proprietary' taints kernel.
<4>[ 8.168148] Disabling lock debugging due to kernel taint
<4>[ 8.169388] RS485_CTRL MUXCTRL(32) FCN0 GPIO9_4 OUTPUT LOW_LEVEL
<4>[ 8.169418] RS485_RXD MUXCTRL(31) FCN1 NO_GPIO
<4>[ 8.169431] RS485_TXD MUXCTRL(33) FCN1 NO_GPIO
<4>[ 8.169444] RS485_2_RXD MUXCTRL(34) FCN1 NO_GPIO
<4>[ 8.169457] RS485_2_TXD MUXCTRL(35) FCN1 NO_GPIO
<4>[ 8.169470] SPI1_SCLK MUXCTRL(24) FCN1 NO_GPIO
<4>[ 8.169483] SPI1_MOSI MUXCTRL(25) FCN1 NO_GPIO
<4>[ 8.169496] SPI1_MISO MUXCTRL(26) FCN1 NO_GPIO
<4>[ 8.169509] SPI1_CSN0 MUXCTRL(27) FCN1 NO_GPIO
<4>[ 8.169522] SPI1_CSN1 MUXCTRL(1 ) FCN2 NO_GPIO
<4>[ 8.169535] SPI1_CSN2 MUXCTRL(2 ) FCN2 NO_GPIO
<4>[ 8.169548] I2C0_SDA MUXCTRL(21) FCN2 NO_GPIO
<4>[ 8.169561] I2C0_SCL MUXCTRL(20) FCN2 NO_GPIO
<4>[ 8.169574] I2C2_SDA MUXCTRL(28) FCN1 NO_GPIO
<4>[ 8.169587] I2C2_SCL MUXCTRL(29) FCN1 NO_GPIO
<4>[ 8.169600] IRIS_PWM MUXCTRL(55) FCN1 NO_GPIO
<4>[ 8.169613] ENCRYPT_CLK MUXCTRL(56) FCN1 NO_GPIO
<4>[ 8.169625] FAR_IR_PWM MUXCTRL(85) FCN0 NO_GPIO
<4>[ 8.169638] NEAR_IR_PWM MUXCTRL(86) FCN0 NO_GPIO
<4>[ 8.169651] ALARM_IN1 MUXCTRL(113) FCN0 GPIO12_6 INPUT LOW_LEVEL
<4>[ 8.169672] ALARM_OUT1 MUXCTRL(111) FCN0 GPIO12_4 OUTPUT LOW_LEVEL
<4>[ 8.169691] ALARM_IN2 MUXCTRL(112) FCN0 GPIO12_5 INPUT LOW_LEVEL
<4>[ 8.169710] ALARM_OUT2 MUXCTRL(110) FCN0 GPIO12_3 OUTPUT LOW_LEVEL
<4>[ 8.169729] IRCUT_1 MUXCTRL(116) FCN0 GPIO13_1 OUTPUT LOW_LEVEL
<4>[ 8.169748] IRCUT_2 MUXCTRL(115) FCN0 GPIO13_0 OUTPUT LOW_LEVEL
<4>[ 8.169767] IRCUT_FB MUXCTRL(105) FCN0 GPIO15_1 INPUT LOW_LEVEL
<4>[ 8.169786] ZOOM_FB MUXCTRL(119) FCN0 GPIO13_4 INPUT LOW_LEVEL
<4>[ 8.169805] FOCUS_FB MUXCTRL(118) FCN0 GPIO13_3 INPUT LOW_LEVEL
<4>[ 8.169823] ABF_FB MUXCTRL(107) FCN0 GPIO12_0 INPUT LOW_LEVEL
<4>[ 8.169842] MOTOR_RSTN MUXCTRL(104) FCN0 GPIO15_0 OUTPUT LOW_LEVEL
<4>[ 8.169872] MFOCUS MUXCTRL(120) FCN0 GPIO13_5 INPUT LOW_LEVEL
<4>[ 8.169891] IRIS_SET MUXCTRL(114) FCN0 GPIO12_7 OUTPUT LOW_LEVEL
<4>[ 8.169910] IR_PHOTO_FB MUXCTRL(87) FCN0 NO_GPIO
<4>[ 8.169923] TEMP_IN MUXCTRL(88) FCN0 NO_GPIO
<4>[ 8.169936] USB_PWREN MUXCTRL(43) FCN1 NO_GPIO
<4>[ 8.169949] USB_OVRCUR MUXCTRL(42) FCN1 NO_GPIO
<4>[ 8.169962] FTY_RST MUXCTRL(117) FCN0 GPIO13_2 INPUT LOW_LEVEL
<4>[ 8.169981] VD_OUT MUXCTRL(106) FCN0 GPIO15_2 OUTPUT LOW_LEVEL
<4>[ 8.170000] MCU_SWIM MUXCTRL(38) FCN0 GPIO10_2 OUTPUT HIGH_LEVEL
<4>[ 8.170019] MCU_PROG_RSTN MUXCTRL(39) FCN0 GPIO10_3 OUTPUT HIGH_LEVEL
<4>[ 8.170038] LED_CTRL1 MUXCTRL(109) FCN0 GPIO12_2 OUTPUT HIGH_LEVEL
<4>[ 8.170094] LED_CTRL2 MUXCTRL(108) FCN0 GPIO12_1 OUTPUT LOW_LEVEL
<4>[ 8.170114] SENSOR_CLK MUXCTRL(0 ) FCN1 NO_GPIO
<4>[ 8.170127] SENSOR_RST MUXCTRL(53) FCN0 GPIO0_0 OUTPUT HIGH_LEVEL
<4>[ 8.170146] PHY_RST MUXCTRL(54) FCN0 GPIO0_1 OUTPUT HIGH_LEVEL
<4>[ 8.170165] VO_CLK MUXCTRL(3 ) FCN1 NO_GPIO
<4>[ 8.170178] VO_DAT15 MUXCTRL(4 ) FCN1 NO_GPIO
<4>[ 8.170191] VO_DAT14 MUXCTRL(5 ) FCN1 NO_GPIO
<4>[ 8.170204] VO_DAT13 MUXCTRL(6 ) FCN1 NO_GPIO
<4>[ 8.170216] VO_DAT12 MUXCTRL(7 ) FCN1 NO_GPIO
<4>[ 8.170229] VO_DAT11 MUXCTRL(8 ) FCN1 NO_GPIO
<4>[ 8.170242] VO_DAT10 MUXCTRL(9 ) FCN1 NO_GPIO
<4>[ 8.170255] VO_DAT9 MUXCTRL(10) FCN1 NO_GPIO
<4>[ 8.170268] VO_DAT8 MUXCTRL(11) FCN1 NO_GPIO
<4>[ 8.170281] VO_DAT7 MUXCTRL(12) FCN1 NO_GPIO
<4>[ 8.170294] VO_DAT6 MUXCTRL(13) FCN1 NO_GPIO
<4>[ 8.170307] VO_DAT5 MUXCTRL(14) FCN1 NO_GPIO
<4>[ 8.170319] VO_DAT4 MUXCTRL(15) FCN1 NO_GPIO
<4>[ 8.170332] VO_DAT3 MUXCTRL(16) FCN1 NO_GPIO
<4>[ 8.170345] VO_DAT2 MUXCTRL(17) FCN1 NO_GPIO
<4>[ 8.170358] VO_DAT1 MUXCTRL(18) FCN1 NO_GPIO
<4>[ 8.170371] VO_DAT0 MUXCTRL(19) FCN1 NO_GPIO
<6>[ 8.186341] Successfully insmod dome_timer module!
<6>[ 8.196284] [motor_init]: insmod motor module successfully
<6>[ 8.213940] initialized demo_event
<6>[ 8.213958] initialized wps_event
<6>[ 8.213968] initialized alarm
<6>[ 8.213977] event_notify build May 14 2015 21:18:30
<6>[ 8.234497] cur support uart:
<6>[ 8.234515] uart1(rs485)
<6>[ 8.234524] uart2(rs232)
<6>[ 8.234532]
<6>[ 8.234539] uart1 cken enable!
<6>[ 8.234547] uart2 cken enable!
<6>[ 8.234840] Successfully insmod uart232 module!
<7>[ 15.520123] eth0: no IPv6 routers present
<6>[ 16.277198] Hisilicon Media Memory Zone Manager
<4>[ 16.285425] Module himedia: init ok
<4>[ 16.310927] load sys.ko for Hi3516A...OK!
<4>[ 16.329941] Load tde.ko ...OK!
<6>[ 16.339991] load region.ko ....OK!
<4>[ 16.358581] load vgs.ko for Hi3516A...OK!
<6>[ 16.375632] ISP Mod init!
<4>[ 16.389431] load viu.ko for Hi3516A...OK!
<6>[ 16.411013] load vpss.ko ....OK!
<6>[ 16.432767] load vou.ko ....OK!
<4>[ 16.454682] Load hifb.ko OK!
<4>[ 16.464658] load rc.ko for Hi3516A...OK!
<4>[ 16.480321] load venc.ko for Hi3516A...OK!
<4>[ 16.495323] load chnl.ko for Hi3516A...OK!
<4>[ 16.511770] load h264e.ko for Hi3516A...OK!
<4>[ 16.527418] load h265e.ko for Hi3516A...OK!
<4>[ 16.541400] load jpege.ko for Hi3516A...OK!
<6>[ 16.556491] load vda.ko ....OK!
<4>[ 16.567342] ive mod init success!
<4>[ 16.619950] acodec inited!
<1>[ 16.686937] mipi_init
<4>[ 16.700164] init phy power successful!
<4>[ 16.700190] load hi_mipi driver successful!
<6>[ 16.721519] regulator_cpu: 0 <--> 1 mV at 1 mV normal
<4>[ 16.750404] load pm.ko ok!.
<6>[ 17.320121] clk_set_rate rate=850
<4>[ 20.120224] ------------[ cut here ]------------
<4>[ 20.120261] WARNING: at drivers/gpio/gpiolib.c:103 gpio_ensure_requested+0x60/0xb0()
<4>[ 20.120271] autorequest GPIO-114
<4>[ 20.120277] Modules linked in: hi3516a_pm(O) hi_mipi(O) hi3516a_adec(O) hi3516a_aenc(O) hi3516a_ao(O) hi3516a_ai(O) hi3516a_aio(O) acodec(O) hi_sensor_i2c(O) hi3516a_ive(O) hi3516a_vda(O) hi3516a_jpege(O) hi3516a_h265e(O) hi3516a_h264e(O) hi3516a_chnl(O) hi3516a_venc(O) hi3516a_rc(O) hifb(O) hi3516a_vou(O) hi3516a_vpss(O) hi3516a_viu(O) hi3516a_isp(O) hi3516a_vgs(O) hi3516a_region(O) hi3516a_tde(O) hi3516a_sys(O) hi3516a_base(O) hi_media(O) mmz(O) uart232(PO) alarm(PO) event_notify(PO) abf_trigger(PO) motor(PO) dome_timer(PO) hi_sspi(O) hikcomm(PO) base(O)
<4>[ 20.120383] Backtrace:
<4>[ 20.120405] [<c001295c>] (dump_backtrace+0x0/0x110) from [<c03c77f4>] (dump_stack+0x18/0x1c)
<4>[ 20.120417] r6:c01e2f14 r5:00000009 r4:c472de40 r3:c06bbf00
<4>[ 20.120443] [<c03c77dc>] (dump_stack+0x0/0x1c) from [<c00200e4>] (warn_slowpath_common+0x5c/0x6c)
<4>[ 20.120462] [<c0020088>] (warn_slowpath_common+0x0/0x6c) from [<c002012c>] (warn_slowpath_fmt+0x38/0x40)
<4>[ 20.120473] r8:00000072 r7:00000001 r6:00000072 r5:c072d2c0 r4:c072d250
<4>[ 20.120489] r3:00000009
<4>[ 20.120505] [<c00200f4>] (warn_slowpath_fmt+0x0/0x40) from [<c01e2f14>] (gpio_ensure_requested+0x60/0xb0)
<4>[ 20.120516] r3:00000072 r2:c04bdf8c
<4>[ 20.120534] [<c01e2eb4>] (gpio_ensure_requested+0x0/0xb0) from [<c01e30e4>] (gpio_direction_output+0x9c/0x10c)
<4>[ 20.120545] r6:c072d2c0 r5:c072d250 r4:40000013 r3:00000080
<4>[ 20.120582] [<c01e3048>] (gpio_direction_output+0x0/0x10c) from [<bf0000bc>] (hik_gpio_direction_output+0x10/0x14 [base])
<4>[ 20.120595] r8:c5b55750 r7:00000000 r6:c472c000 r5:bedb39a0 r4:40044702
<4>[ 20.120611] r3:40044702
<4>[ 20.120639] [<bf0000ac>] (hik_gpio_direction_output+0x0/0x14 [base]) from [<bf004cf0>] (hikio_ioctl+0xa78/0xb28 [hikcomm])
<4>[ 20.120668] [<bf004278>] (hikio_ioctl+0x0/0xb28 [hikcomm]) from [<c00ae3fc>] (do_vfs_ioctl+0x3d4/0x564)
<4>[ 20.120680] r7:c20feb00 r6:bedb39a0 r5:00000006 r4:00000006
<4>[ 20.120703] [<c00ae028>] (do_vfs_ioctl+0x0/0x564) from [<c00ae5c8>] (sys_ioctl+0x3c/0x68)
<4>[ 20.120722] [<c00ae58c>] (sys_ioctl+0x0/0x68) from [<c000eac0>] (ret_fast_syscall+0x0/0x30)
<4>[ 20.120732] r7:00000036 r6:00000006 r5:bedb39a0 r4:40044702
<4>[ 20.120748] ---[ end trace f0042cc0af310f61 ]---
<6>[ 26.604989] event 3 bind pid 1210
