Hello,
Several times I have successfully used the Trendnet camera rescue methods by uploading the firmware via tftp in the same way as for Hikvision cameras.
The cameras started working
Most Trendnet camera is same as Hikvision just diffrent branding and cover i think
Unfortunately, the first time I have a problem with completing the update so that the camera starts.
The model is TV-IP316PI and unfortunately every time the process ends with "Completed file transmit" without last step "Device system update completed!"
At this point, the camera disconnects (you can see it after the ping command) and the process does not end.
There are two red LEDs on the camera.
After it the camera turn on but cant find it on network.
I tried all firmware versions available for this model:
unfortunately the result is the same every time.
It would be great to save it so that it works
On the housing next to the SD slot there is a connector (probably technical UART) but I can't find anywhere a list of which pins have what markings
Has anyone encountered this problem in Hikvision models and managed to fix it somehow?
