I own 7 Dahua cameras which include 5 IPC-HDW4431C-A cams and 1 Starlight IPC-HDW4231EM-AS and the audio problem child in the title. All but this camera have very usable audio. This camera has lots of noise. By noise I mean crackling and squeal (sounds like feedback). I've tried every available encode option, sampling frequencies and volume settings numerous times. I've tried with noise filter on and off. I've also had a piece of microphone windscreen foam over the tiny mic hole.
At this point I am hoping this is a firmware issue but I am not very hopeful. I've not found a firmware update.
Below is the info on my problem child.
I would guess I'm not the only one experiencing this. I purchased this camera from empiretecandy on Ali.
Device Type DH-SD29204T-GN
Software Version2.422.0000.3.R.T4.484.9A.NR, Build Date: 2016-10-09
WEB Version3.2.1.383637
ONVIF Version2.42
PTZ Version2.06.29.RHNVFJCA
ONVIF Version2.42
