I have two tenvis cameras, both are a few years old but upto about a month ago they were working fine.
One has just conked out, cant reset it or anything.
The other one, I have plugged it into my router using ethernet cable.
I then use the Tenvis search tool on my pc
I see the camera listed.
I can see the IP and port (the port is forwarded on my router)
I double click the camera and it opens it in my browser
I can see the live stream, the URL has the local IP and port
Now in the camera settings in the browser i goto Wifi Setting, I see my 2.4ghz wifi network listed (i have 5G but the 5ghz and 2.4ghz are on seperate SSID)
i now enter the correct wifi password
I press save.
The problem starts now, it shows the loading/processing icon animation but just stays like that even after an hour...
No I also cant access the camera in the browser, cant see the camera feed or settings.
Is there a solution?
I press save.
