Hi Folks
I just bought the Tendelux 10 Watt IR illuminator from Amazon.
The question that I got is, how does the IR Illuminator work in regards to turning it off and on?
Is it just a simple on/off switch? If it is just On/Off switch, how are you guys turning it off and on? Do you guys connect it to the smart plug and turn it off and on that way? or Do you manually turn it on and off everyday ?
Thanks
Thanks
