Hey everyone,
Reporting an undisclosed regression in Taylor platform firmware V2.840.0000000.22.R that disables IR LED output while all APIs report normal operation.
Affected cameras:
Every software path exhausted:
The smoking gun: IrCutFilterModes: [], firmware de-registered IR modes from ONVIF entirely. Both CGI and ONVIF accept commands at the API layer but the LED driver doesn't execute. Bug is at HAL level.
Release Notes context: V.22 changelog only mentions "DMSS message subscription." Zero illuminator changes documented. V.23 through V.26 (3 releases in 83 days) all fix ONVIF issues only, no IR fix.
Asking:
Best regards,
Francisco Chavez
Affected cameras:
- 1x DH-IPC-HFW2449S-S-IL (on V.22)
- 2x DH-IPC-HDBW2441E-S (updated to V.26, still broken)
- NVR: DHI-NVR4116HS-8P-EI, V4.005
| Test | Result |
| Factory reset | |
CGI Lighting[0][0].Mode=Manual, Light=100 | OK returned — no LED response |
| ONVIF SetImagingSettings IrCutFilter=OFF | OK returned — no LED response |
ONVIF GetOptions → IrCutFilterModes | Empty array [] |
| Update to V.26 | |
Downgrade to V.19 (web + ONVIF Maintenance) | |
| Flash Poland fix V2.840.100J003.0.R | |
| Telnet 23 / 2300 / SSH 22 |
Asking:
- Anyone else hit this on Taylor after V.22?
- Can someone reach this to Dahua R&D?
Best regards,
Francisco Chavez
