Hi all
I am testing a tapo C210 with rtsp. Stream2 works fine, for viewing, even thou its pixelated. Recording stream1 in agent DVR records at 128x780. I cannot view stream1 in Agent DVR, VLC and downloaded ONVIF management tool which fails on stream1. PLayed with all the settings in the tapo app. So i ve come to the conclusion that tapo is a little flakey whern it comes to rtsp feeds.... Unless someone tells me differnet.
My next camera to test after i return this tapo one is the Lorex LE841CAA model. Wondering if Lorex cams are better with rtsp feeds than tapo?
I am frustrated that a simple IP cam cannot access rtsp feeds as advertised by the company.... also discovered this after googling such issues.
Also dont like the fact that you need the tapo app to control the cam to then use it on a 3rd party rtsp setup.
So is Lorex any different/Better/worse...? If you want true RTSP feed should work independantly of there app with a gui interfaced to the camera.....
However i am relative new to this world of ip camera, so will listen to others that have been there done that.
Cheers
Cheers
