T54IR-ZE cable indent(?) plug
SpacemanSpiff
1,856
3,615
USA
Did the T54IR (formerly known as T5442) ever come with a plug for the cable indent (see image below) when the install does not require the cable to exit the housing on the side?
The PFB203W wall mount has a similar indent, and it includes a plug.
I've always used a piece of the closed cel foam packing material they used to use for sealing the opening in the camera base.
Now the packing material is all cardboard, which I surmise won't fair well over time in the wet weather conditions
I've got enough foam stashed to install the 12 cams @EMPIRETECANDY was nice enough to have in stock.
Just thinking ahead at this point
Reactions: CanCuba
All the dahua cams I’ve ever installed (US versions) both plastic and metal, have had a tab there that you’d use your cutters/pliers to break if you’re going to use it.
Reactions: CanCuba
