First let me say I think I'm now so deep in the weeds that part of my problem is my brain is fried from overthinking.
Months ago, when I set my T180 up, I only set it up for triggering through the AI portion of the GUI and I set up BI to only trigger from ONVIF's from the T180.
Somewhere along the way, maybe I inadvertently changed a setting, the triggers for daytime work as expected.
I say that because I have two other Dahua cams facing the same street/sidewalk and use the AI setup in those.
However, on the T180, the night time triggers don't catch as nearly as many triggers as the other two cameras, so I figure something got changed by me accidently.
Some of the things the T180 is missing (at night) are obvious big things like cars.
Can anyone suggest some things for me to look at? I'm pretty sure it must have something to do with the day/night profile but I don't know where.
I also have motion detect turned off since I have tripwires set up instead.
Side question, if you set up tripwires or enter/exit areas under daytime profile, does that also work for night profiles or is there a way to set up different AI triggers for night profiles?
