- Jul 12, 2015
- 79
- 40
I've got to get some T-Bar Clips to install some Hikvision Dome Cameras (from Nellys) and I'm looking for suggestions on which ones to buy. I've never used them to install cameras on ceiling grid since I usually use toggle bolts.
My concern is getting ones that are too short/long or too big to fit through the hole and I don't have any cameras on hand to take with me to the hardware store. Has anybody that's done this before have suggestions on which Clips/Nuts to buy
Or are they all pretty much one size/length?
